Is there a way to turn off cosmetic correction when you do not have fast integration specified? The scenario is that I would process images in Pixinsight WBPP with cosmetic correction. I would then take those registered images into autointegration. I turn off fast integration but cosmetic correction still occurs. I don’t think this is a big deal, but it would save some processing time.
Hi John,
Yes, there is an option Other / Other parameters / No CosmeticCorrection to do that.
The cosmetic correction check box only seems to work if fast integration is selected. If you don’t select fast integration, cosmetic correction always appears in the flow chart. I may be missing something ![]()
Sorry, found it. Was looking in the wrong place.
