Hello,
Whatever the project, process startup is blocked with an error message (see attached files).
I don’t understand
Thank you for the help
Olivier
Hi Olivier,
From the error message I am guessing that there is an error when creating the AutoOutput directory. It looks like it does not like the path as it is cut after word Nebula.
This error is coming from PixInsight so it is hard to know more details.
The file path is taken from the light files. There are some options to avoid this problem:
- Move light files to a directory where there are no spaces in the path name.
- In AutoIntegrate script in upper right corner specify a different output directory.
Hi Jarmor,
I’ve made a fatal mistake: there’s a space after the word Nebula, at the end of the folder name.
It’s the classic mistake that’s hard to see.
I’d like to take this opportunity to speak highly of Autointegrate. It’s an excellent module for those who don’t want to get too involved in the Pixinsight “gas factory”.
Thank you for your help.
Regards
Olivier
