A new AutoIntegrate version 1.27 is available. It has some changes that take advantage of new processing updates in PixInsight 1.8.8.10. Version 1.27 checks PixInsight version number and uses older defaults when it is run on PixInsight 1.8.8.9 or older.
In version 1.28 a big cleanup was done. Now those process settings that are not changed from default values are not listed in the code. So any change in PixInsight default values is automatically used by AutoIntegrate. With the current code there is no need for PixInsight version number check any more.
There is of course a small risk that some default value change was lost in the cleanup. So far I have not found any such problem yet.
