Now it is possible to show 13959 different NGC and IC catalog objects on the map. NGC and IC objects can be chosen from the upper left catalog button. NGC and IC catalog layer is not enabled by default.
Visible objects are also clickable. When you click on a marker a short info is written on the panel to the right side of the map. If the Wiki check box is checked then the Wikipedia page of that object is shown when possible.
