All Slooh 500 object names are added as a catalog layer to the map view. Each Slooh 500 object name is written next to that object on a map. So now it is easier to identify major objects in a map. There is a new control button on the upper left corner of the map where this feature can be disabled or enabled. By default it is enabled. Also the base map can be changed there. Teide and Chile scoped have a different list of Slooh 500 objects.
There is also an option to view the map in full screen mode. A button to control full screen mode is added to the upper right corner of the map.This makes it easier to see a bigger picture when browsing the map.
