AutoIntegrate processing engine is separated from AutoIntegrate GUI so the engine can be called without the GUI. This makes it possible to create own interfaces to AutoIntegrate engine or embed it to other PixInsight script.
Below is a sample to show how to call AutoIntegrate engine from a PixInsight script.
// TestCalibrate.js
// run --execute-mode=auto "C:/Users/jarmo_000/GitHub/TestAutoIntegrate/FullProcessing/TestCalibrate.js"
#include "../../AutoIntegrate/AutoIntegrateGlobal.js"
#include "../../AutoIntegrate/AutoIntegrateUtil.js"
#include "../../AutoIntegrate/AutoIntegrateLDD.js"
#include "../../AutoIntegrate/AutoIntegrateBanding.js"
#include "../../AutoIntegrate/AutoIntegrateEngine.js"
try {
var global = new AutoIntegrateGlobal();
var util = new AutoIntegrateUtil(global);
var engine = new AutoIntegrateEngine(global, util);
global.lightFileNames = [
"D:/Telescopes/test/Calibrate/OSC_engine/Light_001.fit",
"D:/Telescopes/test/Calibrate/OSC_engine/Light_002.fit",
"D:/Telescopes/test/Calibrate/OSC_engine/Light_003.fit",
"D:/Telescopes/test/Calibrate/OSC_engine/Light_004.fit"
global.biasFileNames = [
"D:/Telescopes/test/Calibrate/OSC_engine/Bias_001.fit",
"D:/Telescopes/test/Calibrate/OSC_engine/Bias_002.fit",
"D:/Telescopes/test/Calibrate/OSC_engine/Bias_003.fit",
"D:/Telescopes/test/Calibrate/OSC_engine/Bias_004.fit"
global.darkFileNames = [
"D:/Telescopes/test/Calibrate/OSC_engine/Dark_001.fit",
"D:/Telescopes/test/Calibrate/OSC_engine/Dark_002.fit",
"D:/Telescopes/test/Calibrate/OSC_engine/Dark_003.fit",
"D:/Telescopes/test/Calibrate/OSC_engine/Dark_004.fit"
global.flatFileNames = [
"D:/Telescopes/test/Calibrate/OSC_engine/Flat_001.fit",
"D:/Telescopes/test/Calibrate/OSC_engine/Flat_002.fit",
"D:/Telescopes/test/Calibrate/OSC_engine/Flat_003.fit",
"D:/Telescopes/test/Calibrate/OSC_engine/Flat_004.fit"
global.flatdarkFileNames = [
global.par.debayer_pattern.val = "GRBG";
engine.autointegrateProcessingEngine(null, false, false);
} catch (x) {
console.noteln("TestCalibrate failed, catched error: " + x);
