I´m not sure whats the Reason: Autointegrate is´nt sorting my Darks or Flatdarks anymore regarding the Filter they are exposed with. I´ve checked it with older and actual Files and compared also the Fitsheader. The Keywords Filter and Image-Type are set, f.e. Filter G and Flat or Dark. This looks normal.
If I load these FlatDarks as Flats or Image, they will be sorted correctly, but not in the FlatDark-Section.
Running the Script I can see at the Process-Console the Error-Message: Missing Meta-Data.
I have some trouble reproducing the problem. Would it be possible to get more information like autointegrate.log file, or console output if there is no autointegrate.log?
As you see, there is only one flatdark integrated. But I loaded 5 (LRGBHa). And as I understand the following integration is using this one Flatdark for all Flats.
Shouldn’t a separate integration be shown here for each Flatdark?
I do not do much calibration myself, and I do not seem to have any test material for flat darks (or dark flats). I also remember it was pretty painful to try to understand what flat darks really are So it is possible that they are not handled correctly. I need to get back to reading some info on those.
Any additional info you may have is of course very useful. For example those Json files, or autointegrate log files can be useful. If you are willing to share a subset of data for my test use, that would be great too. A very small subset like 1-3 files for each category (lights, flats, etc.) should be enough as I am testing only processing and not the final results.
My understanding is that flat darks are dark frames used to calibrate flats. They are used in the same way as darks are used to calibrate lights. As with darks, they are not sorted by filter. Please feel free to correct if I have misunderstood this.
I answered to the Email I´ve got from the Forum. The Email came back today…
This I wrote:
You misunderstood that. CMOS cameras are different than CCD cameras. We need darks with exactly the same exposure time as the flats. This means that the flats and flat darks belong together, are a pair and should therefore be sorted in the same way as the flats and lights. Otherwise, the flats don’t really match the light images. The flat darks are treated like bias images. Therefore, the lights must also be calibrated with a bias, otherwise they will be overcorrected.
Thanks for clarifying this. I did check some YouTube channels but obviously misunderstood the vague terms they were using. As in many other cases, I did get the best answer using AI bot (and obviously from you).
I hope to get this corrected in a few days. It would be great if you could verify it using my debug repository before I put out the final version. I will post a note here when I think it is ready.
I am using just free tools for this forum and emails posted from the forum. So my setup is very simplistic one and and does not support email replies.
-----I am using just free tools for this forum and emails posted from the forum. So my setup is very simplistic one and and does not support email replies. -----
Hi Jarmo, that wasn’t a criticism, but an explanation for why my reply was so late. I wasn’t paying attention again…
I’m very grateful for your work, and I’ve been wondering for a while why you’re making all this available for free. I’d be happy to make a donation.
I have pushed a test version to my debug repository at https://ruuth.xyz/debug/autointegrate/. It would be great if you can try it out and give feedback. I was unable to locate a real test case for flat darks so I just simulated it. So I have no idea if the image quality is good or if something goes wrong.
I have been doing this script (mostly) just for my own use and as a learning process. There’s no need to donate, but if you’d like to support my work, you can do so via the following link: PayPal.Me
Thanks for the note. I have been planning to put out a new version but have been testing the DBE support. But I guess it it what it is and I’ll update it later if needed.
I have now put out a new version to my test repository at (https://ruuth.xyz/test/autointegrate/). I hope to put out the generic version in a few days.
