Changes in AutoIntegrate v1.87.x
v1.87.4
- New checkboxes in MLDenoise settings high-precision inference and local support. Local support settings uses MLDenoise defaults.
- Fixes to ImageIntegration, LocalNormalization and DrizzleIntegration with less than three files.
- Skip operations for a single image, fail on two images.
v1.87.3
- Preview cache and prefetch when browsing files
v1.87.2
- Support for MLDenoise
- Settings are in the Postprocessing / Noise reduction section:
- Model, a path to the model file. Model files have a .xmlm extension. The path is is saved immediately to the persistent module settings and is not reset. If no model file is given then the MLDenoise will fail with an error.
- Amount, the amount of noise reduction, default 0.90.
- There is no model parameter in StarXTerminator process options any more.
- Noise reduction is by default run on processed linear image by default in alll cases.
- Updates to Ha and RGB continuum subtraction
- Bug fixes in flowchart, extract channels and finding filter files in some rare cases.
v1.87.1
- NoiseXTerminator settings are updated to the current process parameters.
- Small UI and parameter updates
- New Write options metadata button in the Interface tab
- Bug fixes
