PixInsight repository for AutoIntegrate is https://ruuth.xyz/autointegrate/.
Changes in this version are listed below.
MultiscaleGradientCorrection
- Added support for MultiscaleGradientCorrection.
- MultiscaleGradientCorrection may fail if the image is not part of the sky area in the MARS database. In that case the script reverts to another gradient correction method. If other gradient correction methods are checked then they are selected in the following order: GraXpert, ABE, GradientCorrection.
- When MultiscaleGradientCorrection is used, image solving and SpectrophotometricFluxCalibration are run automatically.
- MultiscaleGradientCorrection is available only in PixInsight 1.9.0 or later.
Other
- Again some generic fixes to image solving.
- Added an option for interactive image solving that open image solver dialog.
- Added an option to set output pedestal for image calibration in a new Image Calibration section.
- Added an option to use chrominance instead of saturation to boost colors.
- Option Reset on setup load is now enabled by default.
