Changes in AutoIntegrate v1.70 are listed below.
DeepSNR denoise
- Support for denoise using DeepSNR. DeepSNR must be installed
to the PixInsight before it can be used.
Add signature to an image
- Added an extra processing option to add a signature file to the image.
Image file must be given by the user. - The signature file can be for example a .png image with a transparent
background. Note that no borders are added to the image. - Optionally the signature image can be scaled relative to the main image.
The scaling is given as a percentage of the main image size. - Signature position can be chosen: ‘Top left’, ‘Top middle’, ‘Top right’,
‘Bottom left’, ‘Bottom middle’, ‘Bottom right’.
FastIntegration changes
- Fix when finding the integrated image.
- New section for FastIntegration settings.
- Fast SubframeSelector is used to find the reference image when FastIntegration is enabled. Only 10 first
images are evaluated. This can be disabled in FastIntegration settings. - By default cosmetic correction is not done when using FastIntegration. This can be changed in FastIntegration settings.
- Drizzle can be used with FastIntegration.
- Some changes to default values for FastIntegration.
Flowchart changes
- Flowchart is now enabled by default.
- By default the processed image is shown in the background of the flowchart.
It can be disabled in the flowchart settings. - By default Flowchart shows processing time. It can be disabled in the
flowchart settings. - Text version of the flowchart that is printed to the log file always
prints processing time. - Flowchart related options are moved to the interface tab.
- Optionally the flowchart image can be written to AutoProcessed directory when processing is completed
Preview AutoSTF option
- Added an AutoSTF option to show the preview image during processing always
in a stretched format. It can help visualize the processed data. Option is
enabled by default and can be toggled during the processing.
AutoContinue start prefix
- Added a textbox to give the start prefix for AutoContinue. It is used
if current window prefix images are not found. Previously only window
prefix or empty prefix could be used for AutoContinue start images.
Annotate scale
- Added scale option to control annotate image text size.
Other
- Drizzle scale can now be between 1 and 10.
- New section for debug settings in the interface tab.
- Image metadata is copied to integrated images. This helps with some problems with ImageSolver.
- Processing history is added to the image FITS header.
- Fix to Extra processing Solve image when copying astrometric solution from another image. Return error if image dimensions do not match.
