Changes in v1.53
- Added option Save processed channel images
- It saves processed channel images with name Integration__processed.
- Processed files may make experimenting with different stretching or narrowband mapping faster because possibly time consuming operations like noise reduction (slow with NoiseXTerminator) is already done.
- Added checks that the output directory is created and it is writeable. As a result each directory contains an info.txt file.
- New option Extra saturation to increase saturation after basic processing
- Fix to use correct image window in PixelMath
- Added option Extra smooth background to smooth uneven background. A limit value below which smoothing is done is given.
- Small change to crop algorithm to allow single zero pixels.
- Added current pixel value to preview info at the bottom.
- Use H as the first choice for linear fit with narrowband images.
- StarXTerminator 2.0.0 support
